Adding Roles after syncing Audio
Thomas Frank
on Aug 19, 2014 at 5:36:47 am
I have a project where the Audio and Video have been syn.
If assign Roles to the RAW audio, will it also assign the Audio in the sync clips or will I have assigned it separated?
Robin S. Kurz
Re: Adding Roles after syncing Audio
on Aug 19, 2014 at 8:28:36 am
If you did not assign the roles BEFORE synching, then you will have to do the synced clips manually. Role assignments are (fortunately) not recursive. The same goes for clips in the project timeline. If you assign a role to a clip in the timeline, that change won't be reflected in the master in the event, as well as the other way around.
