Path to Destinations settings
Patrice Freymond
on Aug 18, 2014 at 11:21:43 am
I am setting up 2 new Mac Pros and would like to copy FCPX 10.1.2 destinations settings from one to the other.
On my laptop under 10.9.4 I have two Libraries in the system, and at User level there is Applications Support > Pro Apps > Export Presets
On the new MP there is only one Library level and no such folder in App support...
Anybody know where to find it ?
Patrice
Jeremy Garchow
Re: Path to Destinations settings
on Aug 18, 2014 at 2:59:17 pm
[Patrice Freymond] "On the new MP there is only one Library level and no such folder in App support...
From the Finder, hold option, and choose the "Go" menu. You will see the user library at that point.
You'll find the Applications Support > Compressor folder in there.
The other thing to do is to save all of your settings as a droplet (you can do this by selecting them all, right clicking, and choose "Save as Droplet") right from Compressor.
Then on the other machine, drag that .app file in to the custom settings area of Compressor.
Jeremy
Patrice Freymond
on Aug 18, 2014 at 8:00:01 pm
Thanks Jeremy, this helps.
I am after FCPX's presets in fact. I hope they are not tagged per machine so I can easily transfer them from one machine to the next.
I'll look into it.
Thanks again,
Patrice
Jeremy Garchow
on Aug 19, 2014 at 4:00:21 pm
[Patrice Freymond] "Thanks Jeremy, this helps.
I am after FCPX's presets in fact. I hope they are not tagged per machine so I can easily transfer them from one machine to the next."
I have no idea why I sent you to Compressor.
Apologies!
Paul Figgiani
on Aug 19, 2014 at 12:16:05 am
It's documented in the Developer docs.
Look Here under the heading "Custom Share Destination."
-paul.
Patrice Freymond
on Aug 19, 2014 at 5:55:48 am
Again, thanks,this is a document I wasn't aware of.
Patrice
Jeremy Garchow
on Aug 19, 2014 at 4:07:28 pm
[Paul Figgiani] "It's documented in the Developer docs.
Look Here under the heading "Custom Share Destination.""
Thanks, Paul.
I learned something today!
It's as easy as dragging the destinations out of the pref window to the finder.
The destinations don't seem to be stored in the file paths mentioned in the developer docs, though.
Jeremy
Paul Figgiani
on Aug 19, 2014 at 4:37:47 pm
You're welcome, guys.
-paul.
