C300 import?
Bret Williams
C300 import?
on Aug 16, 2014 at 5:18:53 am
I've installed the plugin and the utility but still I can't see c300 footage in the import window. I can see it just fine in the canon utility. I have a hard drive from the client. On the drive is a folder with the name of the shoot, and within that a contents folder. I I drag the whole folder to the event, it says there's nothing it can recognize or import. If I access the folder from the import window it thinks for a quick second and then it's blank. Am I missing something?
Here's a shot of the folder -
Bret Williams
Re: C300 import?
on Aug 16, 2014 at 6:10:40 am
Nevermind it's working. But still can't get filmstrip mode.
Bob Woodhead
Re: C300 import?
on Aug 16, 2014 at 11:51:09 am
I use C300/100 footage every day for last couple years. Never had a problem using the Canon plugin. Just popped over to the Canon download page, and I see there's a (much) newer import plugin available (as of 6/26/14). If you just downloaded, perhaps a bug in the new version? Maybe Canon can send you an old version to test.
Dan Hodlick
Re: C300 import?
on Aug 20, 2014 at 1:18:51 pm
Just to bounce this back to the top - FCPX will not import C300 footage at all. I've downloaded and installed the latest drivers and plugins - no joy.
Works fine in premiere pro on the same computer
