Create multiple titles with the same X and Y starting point?
Tim Jones
on Aug 6, 2014 at 9:52:35 pm
Hi Folks,
Grabbing something line the "Continuous" title effect, is there some way to create the first of a bunch of instances with a custom position for the starting X/Y position such that the additional instances use that same starting position?
I've been digging through the settings, and it seems that everything but the starting position is available.
Do I need to go out to Motion and create my own version?
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
Bill Davis
Re: Create multiple titles with the same X and Y starting point?
on Aug 6, 2014 at 9:56:36 pm
Won't it work making the first title into a compound clip, then dragging it into multiple places in the storyline and after breaking the "parent" links, customizing each compound with new coordinates?
Seems like it should work.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Tim Jones
on Aug 6, 2014 at 11:01:46 pm
It turned out to be even simpler than that - Copy and Paste. I was determined to find a "Cuplicate" option and the obvious totally escaped me.
Tim
Tim Jones
Bill Davis
on Aug 7, 2014 at 4:59:22 am
Yes, IIRC that works for compounds that you create in a storyline. But I'm not sure it works for compounds you pre-creates in the Event Browser. I think the changes you make there are inherited across all instances of the compound placed in any storyline across Events. Unless I'm mistaken. No time to test it now.
Robin S. Kurz
on Aug 7, 2014 at 9:02:27 am
[Bill Davis] "Yes, IIRC that works for compounds that you create in a storyline. But I'm not sure it works for compounds you pre-creates in the Event Browser. I think the changes you make there are inherited across all instances of the compound placed in any storyline across Events."
Changes made to ANY compound clip (however that is relevant here) is recursive to it's existing instances, even across multiple projects, yes. It's irrelevant how and where you created it.
Robin S. Kurz
on Aug 7, 2014 at 8:59:26 am
Yes, either copy/paste or simply OPTION-DRAG in the timeline! No idea why you would want to use or need a compound clip.
Tim Jones
on Aug 7, 2014 at 3:10:17 pm
I remembered OPT-Drag last night. Like I said, I was totally overthinking the needed result and went 'round my fist, so to speak.
Oh, and I'm not using compound clips for this, just dropping the title generator where needed.
All is well now.
Tim
Tim Jones
