Problems sharing FCP X project
Stuart Platt
on Jul 27, 2014 at 3:26:25 pm
I'm in a bit of a panic.
I'm using FCP 10.08 on OS X.8.5
I've just finished editing a project and trying to share but both the share options and send to compressor options are greyed out.
I've not had problems before but I recently got a Canon C300 and have been using the Canon software to bring in the footage. I've used it before with no issues but I've noticed that some of the clips are spread across 2cards - could that have something to do with it?
Any thoughts or help would be very much appreciated.
Robin S. Kurz
Re: Problems sharing FCP X project
on Jul 27, 2014 at 4:24:55 pm
You need to make sure that the actual project is selected/active. Either by clicking in the timeline or selecting it in the project library. In the old version one could easily change to/activate the Event browser when passing over it on the way to the menu. Drove me nuts.
Your best bet is to simply use the Share Menu at the far right of the toolbar/dashboard. That way you're not passing over anything with your mouse.
... then upgrade to Mavericks/10.1.x. ;)
Stuart Platt
on Jul 27, 2014 at 4:34:31 pm
Thanks for the quick reply.
I just tried that and getting "This item cannot be shared while it is still referencing media on the camera."
Any thoughts?
Robin S. Kurz
on Jul 27, 2014 at 4:38:36 pm
Ah. Then you didn't let FCP finish the import of the footage from the camera. I'm guessing you have a little camera icon on some or even all of your clips in the event. You need to connect the camera/card and choose "Reimport from camera/archive" first and let the import finish.
Stuart Platt
on Jul 27, 2014 at 4:48:52 pm
That looks like it!!!
Thank you so much Robin!!!!
I can't tell you how relieved I am!
A million thank yous!
Craig Alan
on Jul 27, 2014 at 9:19:34 pm
command-9 is your friend
"FCP 10.08 on OS X.8.5"
and when you're done sharing ... up-date. A lot has happened for the better.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Robin S. Kurz
on Jul 28, 2014 at 7:44:48 am
[Stuart Platt] "That looks like it!!!"
Glad it helped.
[Craig Alan] "command-9 is your friend"
Um... how so?
Craig Alan
on Jul 28, 2014 at 4:38:27 pm
[Robin S. Kurz] "[Craig Alan] "command-9 is your friend"
Um... how so?"
Lets you know status of b.g. tasks.
Although FC lets you cont. to work when a b.g. task is incomplete, on the computers I've used, it simply pauses the task.
