h.264 / proxy / optimized workflow question
Alex Mallis
on Jul 9, 2014 at 7:54:32 pm
Pretty excited about 10.1.2.
I'm shooting a c100/5diii. I have a couple questions about best ingest/export practice:
1. If I create only proxies, and then choose 422 for my final export, will the conversion be sourced (right word?) from the original files, or the proxies? Does this matter?
2. If I only use proxies for footage originally shot h.264, am I at a disadvantage when adding color correction vs using optimized 422? Alt phrasing: Are the proxy files more compressed than the original media? Would it make a difference to upres further to 422 if I expect to add color in the edit?
3. Related to question #1, if I intend to pass off a project to a colorist, is there any reason not to edit in proxy and then export a prores422 of only the final cut?
Thanks a mill
Alex Mallis
Re: h.264 / proxy / optimized workflow question
on Jul 15, 2014 at 6:39:18 pm
bumpsky
Alex Mallis
AnalectFilms.com
brooklynfilmmakerscollective.com
Hugh Chaloner
on Aug 14, 2014 at 12:58:24 pm
1. yes, it does matter, recreate from originals.
2. proxies are compressed to f*ck, so if fine detail is important to your eye when setting a colour correction, then yes, you should colour correct using the ProRes media
3. no, there's no reason not to (how many negatives can we get into a sentence?)
http://www.intercuts.com
(m) +353 (0)86 603 0987
