Is there a way to adjust the shape of a line between two animation points so I can have a smoother fade in/fade out?
Pete Johnson
on Jul 7, 2014 at 1:08:09 pm
Is there a way to adjust the shape of a line between two animation points so I can have a smoother fade in/fade out? I guess this is how it was done but it doesn't seem to work like this any longer.
http://www.larryjordan.biz/fcpx-keyframes/
Andy Neil
Re: Is there a way to adjust the shape of a line between two animation points so I can have a smoother fade in/fade out?
on Jul 7, 2014 at 4:31:32 pm
Actually, it works exactly the same way. You can create keyframes and then right-click a segment between them and choose your easing method. Or you can apply a dissolve transition and adjust it's easing in the inspector. The only things it won't work on are fade handles.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Craig Alan
on Jul 8, 2014 at 2:56:38 am
For audio fades, right click on the fade handle itself and you can choose a shape. For opacity fades, open the video animation on the clip and instead of using the built in fade handle, create your own with two key frames and then you can create others on the line or select a shape by control clicking. Or select ease by command clicking on the line.
Andy didn't we used to be able to change the shape on the fade handle?
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Pete Johnson
on Jul 9, 2014 at 2:14:05 am
Thanks that's exactly what I needed, I was about to repost that I was trying to do it on an audio file.
