Smart backup of Library packages?
James Culbertson
on Jul 2, 2014 at 11:56:38 pm
Is there an application that can smart backup a library package?
I use ChronoSync for backup currently, but even if there is only a small change to the project portion of a library package, Chronosync wants to backup the whole library package again. Kind of a PITA when you have 100's of Gigabytes or more in a library package.
Dave Jenkins
Re: Smart backup of Library packages?
on Jul 3, 2014 at 1:29:07 am
Smart Sync (full version) will back up just what's changed inside the package. I've e-mailed the developers with suggestions. Each time within a week they implemented my suggestions.
It can be found on the App Store.
Dajen Productions, Santa Barbara, CA
Mac Pro 3.5MHz 6-Core Late 2013
FCP X
Tim Jones
on Jul 3, 2014 at 3:45:16 am
Of course, my favorite is BRU PE which will not only backup the bundles, but also track down any referenced files.
You can create a Full job that contains your bundle libraries and then create an incremental definition that will only include the modified/added files.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
Brett Sherman
on Jul 3, 2014 at 4:32:32 am
Have you tried checking the "Dissect Packages" option in Chronosync?
James Culbertson
on Jul 3, 2014 at 5:14:52 am
[Brett Sherman] "Have you tried checking the "Dissect Packages" option in Chronosync?"
Ah, that sounds like a winner. I searched the documentation for packages but nothing turned up.
Robin S. Kurz
on Jul 3, 2014 at 7:46:12 am
Then there's always the very pragmatically named Backups for Final Cut Pro: https://itunes.apple.com/app/backups-for-final-cut-pro/id586594646?mt=12
Robin S. Kurz
on Jul 3, 2014 at 9:12:58 am
But I personally simply use FCP's own backup feature and have set it to back up to my Copy folder. https://copy.com?r=D4Fz3M
