moving FCP library without the connected media
Tony Peck
on Jun 13, 2014 at 12:34:25 am
I would like to either move the Library or the projects if it is possible to another hard drive. My problem is the Library is very large. I would like to send a project or Library without any media in it and I'll reconnect the media later. Is this possible?
Tony
Jeremy Garchow
Re: moving FCP library without the connected media
on Jun 13, 2014 at 5:22:49 pm
Is the media managed, generated, or external?
If it's managed, you'll have to consolidate the media out of the library, then make a new library on the destination hard drive, then drag what you want from the current library to the new one (or select what you want and use the File >Copy.... commands.
If it's generated or external, so the same as above without the consolidation step.
Jeremy
