Universal Audio Change
Tony Peck
on Jun 12, 2014 at 8:20:29 pm
I have a one hour timeline. All the audio is a little low. Is the a easy way to increase the audio levels for the entire timeline. I know I can adjust every clip Individually but I was trying to save some time.
Tony
Jerome Raim
Re: Universal Audio Change
on Jun 12, 2014 at 10:02:20 pm
Select all audio elements --> Ctrl + =
(http://support.apple.com/kb/PH12576?viewlocale=en_US)
You're limited to adding +12dB.
If that's not enough, you can mass apply an audio gain filter to all individual clips.
Or you can compound your entire project and raise the audio level of the compound clip.
Jerome Raim
Post-Production
JeromeRaim.com
