Export to a Jumbotron
John benton
on May 30, 2014 at 4:08:46 pm
Hello all
I have a jul going to a Jumbotron
I am using FCPX but am slightly confused about the Data Rate
here are the specs they need:
Hi-Res QuickTime file
(Apple Pro Res codec preferred)
• 16x9 aspect ratio
• Minimum 3000 kbps data rate ?
• Minimum frame size:
854x480 pixels
What I am wondering about is the Data Rate in FCPX
Any ideas?
~be
Andy Neil
Re: Export to a Jumbotron
on May 30, 2014 at 4:35:30 pm
I'm pretty sure the data rate has to do with compression. If you were going to give them H264 as opposed to Apple pro res you would want the data rate over 3000 Kbps.
I'm sure you'll be fine exporting them standard pro res or pro res HQ
Andy
https://plus.google.com/u/0/107277729326633563425/videos
John benton
on May 30, 2014 at 4:46:43 pm
Great Andy !
Thank you!!
Be
Claude Lyneis
on May 30, 2014 at 10:51:07 pm
I just did one for CAL's memorial stadium Jumbotron. You can always set the data rate using Compressor. In my case I used H.264 and 1280 by 720 30 fps and 5 kps. More or less standard for exporting to Vimeo.
John benton
on May 31, 2014 at 2:01:11 am
Great to hear
Thank you!
Be
