FCPX 10.1.1 XML exchange
Florian Gintenreiter
on May 21, 2014 at 7:43:57 pm
Hi!
Can anyone confirm this:
I have a library, which contains multi clips with 2 camera-angles in them. I edit a project and then export a XML. When I reimport the XML in FCPX the edit imports fine, even the compressor on the audio and audio levels imported, but scaling, positioning, cropping and color-correction information is lost.
In the same library I tested it with an edit without multi clips and there alle the attributes imported fine, including scaling, cropping, color etc.
Is this a bug?
________________________________________
Director of Photography, Director, Editor
Vienna, Austria
Charlie Austin
Re: FCPX 10.1.1 XML exchange
on May 21, 2014 at 10:05:36 pm
[Florian Gintenreiter] "Is this a bug?"
I think it's just a limitation in the current version of fcpxml. Hopefully it'll be improved going forward...
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
