changing the length of a still or movie clip with transitions at both ends.
anita sancha
on May 18, 2014 at 9:04:13 am
Hi all..
How do I change the length of a still or movie clip with transitions at both ends without having to delete the transition at one end to grabb the handle and the reducing the clip .... this is not retiming as a still can't be retimed using retime ... just changing the duration because i can access the retime using command and R.
Cheers
Thanks for all your help
Anita Sancha.
http://www.anitasancha.co.uk
Trust Helpful
Re: changing the length of a still or movie clip with transitions at both ends.
on May 18, 2014 at 9:49:20 am
Hello Anita Sancha
Grab in the middle of the transition on the two arrows pointing at each other at the end of the clip and drag the clip as long as you want it to be.
Trust
Bret Williams
on May 18, 2014 at 2:23:35 pm
Ctrl D, then type in duration
Bret Williams
on May 18, 2014 at 2:26:23 pm
FWIW you don't have to delete the transition to drag out the duration either. You have to zoom in close enough, but there's a grab handle at the upper portion of the dissolve that drags out the clip, not the transition.
anita sancha
on May 18, 2014 at 4:41:11 pm
Thanks... just what I needed. x
Anita Sancha.
