Is there a subtitle plugin for FCPX 10.1.1 that mimics the YouTube 'transcribe and sync' captions?
Peter Dunphy
on May 16, 2014 at 7:41:18 am
Hi Guys
Is there a subtitle plugin available for FCPX 10.1.1 that mimics the YouTube 'transcribe and sync' captions?
I've seen a YouTube video where someone prepares all the subtitles as individual .psd files then cuts each into place on the timeline, but seems too slow a process for what would need to be a quick turnaround for me (which I can achieve with YouTube 'transcribe and sync')
If there isn't a plugin available like the one I'm enquiring about, what would be the next best plugin available?
Warm regards
Peter
Gerry Fraiberg
Re: Is there a subtitle plugin for FCPX 10.1.1 that mimics the YouTube 'transcribe and sync' captions?
on May 16, 2014 at 5:26:58 pm
I've had good results with DH_SubtitleX by Digital Heaven $29.99 plugin.
http://www.digital-heaven.co.uk/dh_subtitlex
You do have to do the work. It works as a Title in FCP X. You have to do the transcription, then enter the text directly into DH_SubtitleX. Timing has to be set visually and manually, but it works nicely.
Here's an example of subtitles for people with hearing loss:
Trust Helpful
on May 16, 2014 at 9:04:44 pm
Peter
I don't know of a plugin.
Annotation Edit will export to youtube captions and can import from a variety of formats.Also has a transcription Service.
Trust
Andreas Kiel
on May 17, 2014 at 1:17:12 am
Have you tried my X-Title Import app. It supports Subrip SRT, Youtube SBV and Spruce STL.
http://www.spherico.com/filmtools/TitleExchange/XTI/index.html.
Works quite easy and painless and comes with some title templates which are designed for subtiles.
- Andreas
Spherico
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Michael Sanders
on May 17, 2014 at 12:40:11 pm
Andreas.. sorry I never got round to trying your app.
Will have a play next..
Michael Sanders
London Based DP/Editor
Andreas Kiel
on May 17, 2014 at 5:08:00 pm
I forgot to mention that there is also an app which allows to export subtitles from FCPXML.
http://www.spherico.com/filmtools/TitleExchange/XTE/XTE%20Install.dmg
There is also an additional subtitle template which can be used to setup subtitles for HD using the European (EBU) rules. It allows to show the EBU standard vertical cell height. This way when using a certain font the font size and paragraph leading can be adjusted to match the rules.
So for 'large' subtitles you setup the lines should cover 2 cell heights, for 'small' subtitles it should cover 1 cell height. For both including descenders and paragraph leading.
The 'grid'] 'cell' rules only apply to burned in subtitles for standard broadcast. Web based broadcast does have different rules. But the lines are also a good help here to set up subtitles - never go into the bottom or top cell.
Here some screenshots from web broadcast.
Download template here:
http://www.spherico.com/filmtools/TitleExchange/XTI/EBU%20TextUp.dmg
The reason I did this template is that Apple is going towards to support system wide the WEBVTT and TTML standards.
With X 10.1 they did the first step for FCP X.
Using the right subtitle template each position can be extracted to make your subtitles fit the needs of the delivery format.
- Andreas
Spherico
