'Compress>Archive' FCPX10.09 App, save zipfile... can I install this on Mavericks MBPro later?
Stephen Underwood
on May 16, 2014 at 12:04:40 am
Hi, Selling an iMac with FCPX 10.09 on it. (About to wipe the drive). I'd like to be able to install this older version on my new MBPro (running Mavericks w/FCPX 10.1) if needed later. Can I do this? If not, please advise on how to archive the older version. Thanks!
~ Steve Underwood
Computer: MacBook Pro, OS X 10.9.2
Processor: 2.6GHz, Intel Core i7, Memory: 16GB
Intel Iris Pro, NVIDIA GeForce GT 750M, FCX 10.1.1
Pegasus 4TB RAID
Andy Neil
Re: 'Compress>Archive' FCPX10.09 App, save zipfile... can I install this on Mavericks MBPro later?
on May 16, 2014 at 12:43:45 am
You can't have both versions on the same system drive, but you can save and reinstall 10.09 by zipping it up. I have all the old versions of FCP archived in this way.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Stephen Underwood
on May 16, 2014 at 1:11:06 am
Thanks for the info and the reassurance!
~ Steve Underwood
Pegasus 4TB RAID
Marco Feil
on May 16, 2014 at 11:51:38 am
You can have both installed on the same drive, you just need to rename one of the Apps, like "Final Cut Pro 10.0.9.app". I always backup and rename or delete "~/Library/Application Support/Final Cut/" and all the Final Cut Prefs in "~/Library/Preferences/" before I use the older Version.
