extending a gap clip
Mark Smith
on May 14, 2014 at 11:41:06 pm
I had a funny situation where I needed to extend a gap clip in the middle of the time line by 15 frames. Control D doesn't do the trick, if I try the trim function I wind up shortening the next clip to the right in the time line which idon't want to do . I added a 15 frame gap in the end but it seems like there should be a way to extend the gap clip I already have in place, right?
Charlie Austin
Re: extending a gap clip
on May 15, 2014 at 12:41:13 am
[Mark Smith] "if I try the trim function I wind up shortening the next clip to the right in the time line which idon't want to do . "
Make sure you're using the select tool (A) rather than the Position tool (P) The latter will eat into the adjacent clip, the former will do what you want, and push everything back
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Mark Smith
on May 15, 2014 at 2:11:26 am
Thanks -you are 100% correct a mundo. I Knew It had to be something simple.
Charlie Austin
on May 15, 2014 at 4:48:09 am
[Mark Smith] " I Knew It had to be something simple."
It usually is. ;-)
