How can I see a multicam clip's original timecode
Steve Sweitzer
on May 3, 2014 at 3:28:19 pm
I'm trying to read the original timecode from a clip within a multicam clip but the TC zeros at the beginning of the multicam when I create it.
Longer story. I burn timecode into an interview clip and share it with a client. They pick their bites. Now I combine that clip with other camera angles to make my multicam but, after I lay the multicam into the timeline, I can't find the bites the client picked using the original clip. Is there a way to see the original TC in clips once they are in a multicam clip?
Jerome Raim
Re: How can I see a multicam clip's original timecode
on May 3, 2014 at 10:30:47 pm
2 options:
• Make a new multiclip in which you set the correct starting TC. copy all clips within one angle, paste into the new multiclip's angle. Keep doing it angle by angle.
• If you don't want to make a new multiclip with correct TC, you can go into range mode ("r") and hover your mouse over a clip to read its embedded TC.
Jerome Raim
Post-Production
JeromeRaim.com
