How to remove a dust/water spot in post?
Jack Niedenthal
on May 1, 2014 at 4:31:36 am
I would really like to know how to remove a spot in post (I am always shooting by the sea, so this happens a lot, it happens with dust and also droplets). See the attached picture. Thanks in advance.
Jack Niedenthal
Microwave Films of the Marshall Islands
http://www.microwavefilms.org
http://www.microwavefilms.org/Crickets.html
iMac i7 using Mavericks 10.9.x, HPX 170 using only one 64GB card
I live on an island in the middle of the Pacific, YOU are my only resource.
Roger Bolton
Re: How to remove a dust/water spot in post?
on May 1, 2014 at 10:19:39 am
You can try using CoreMelt "Object Remover" plugin which is part of SliceX to clone an area of the hair next to the spot.
See here:
http://www.coremelt.com/videos/slicex-remove-objects.html
Freelance: Flame - Smoke - Resolve - Nuke - VFX Supervision
Owner / Director: CoreMelt Plugins
Oliver Peters
on May 1, 2014 at 2:51:41 pm
Another option is to use the SliceX layer mask. Works best if your media is progressive and the spot's duration is 1 frame. Steps: Match frame. Advance source 1 frame and mark in/out on that frame. Edit as a connected clip. Apply filter to connected clip and draw shape around the area of the spot. This will let the connected clip portion of that shot hide the 1-frame occurrence of the spot.
Of course, if the duration is longer, cloning may be a better option. You can still use the above method, but offset the XY position to shift clean hair into the area of the spot. (Don't offset the time.)
- Oliver
Orlando, FL
http://www.oliverpeters.com
Jack Niedenthal
on May 5, 2014 at 5:05:11 am
Many thanks, Roger, Slice X is awesome and simple to use. It did the trick, wished I had found it earlier!
Jack Niedenthal
