Semi opacity on a multicam clip?
Martin Phillips
on Apr 29, 2014 at 10:14:55 pm
Just putting a 12 cam live concert together. Would really like to have the piano keyboard dipping in and out behind the singer (for example) on a semi-opacity. What's the best way to go about this?
Many thanks.
Martin Phillips Freelance Cameraman / Producer / Editor
Chesham, Buckinghamshire, UK. http://www.thevideodepartment.co.uk
James Cude
Re: Semi opacity on a multicam clip?
on Apr 30, 2014 at 12:35:08 am
You can only show one angle at a time in a multicam clip. So the easiest way to do what you want would be to duplicate the multicam clip, connect it above the multicam clip as a connected clip and then switch to the desired angle and dial down the opacity. Then you'll have two instances of the same clip, showing different angles.
