FCPX to Compressor with Subtitles/Closed Captions
Jared Schwyhart
on Apr 24, 2014 at 4:53:05 pm
In the old Apple Compressor (4.1 and older I believe), there was a way to add srt files for subtitles and captioning.
How is this possible with Compressor 4.1.1?
I see no way to add this to my MPEG-2 Program Stream.
Jared
Tom Brooks
Re: FCPX to Compressor with Subtitles/Closed Captions
on Apr 24, 2014 at 10:49:33 pm
It's there if you click on the source file in the job. It's in the Metadata area and it supports Scenarist caption file.
MPEG-2 program and transport stream files: Compressor embeds the closed caption data in program and transport MPEG-2 streams using the EIA-608 ATSC protocol.
Jeff Baker
on Sep 15, 2014 at 1:43:46 pm
Thanks! It took me forever to just figure out how to select the Source File in the Compressor window so the Metadata and Caption options would appear.
Tom Brooks
on Sep 17, 2014 at 2:00:30 pm
I hear you. A tool tip or a better label on the interface would help unlock those secrets.
