is there a fix for the paste effects bug?
david fuku
on Apr 21, 2014 at 11:26:49 pm
Hi group,
Not sure if I read this here, but I have found a bug in fcpx 10.1.1 where if I adjust the audio pan mode or equalization and try to copy and paste effects (video and audio) you will not see the window allowing you the user to choose what to paste. Instead fcpx will simply paste everything, which is a problem.
Thanks in advance, Dave
Jeremy Garchow
Re: is there a fix for the paste effects bug?
on Apr 22, 2014 at 3:32:21 am
Equalization is pretty busted in fcpx as it doesn't stick through multiple edits.
I find it best to use the logic filters, and then paste attributes, not effects.
Jeremy
david fuku
on Apr 22, 2014 at 3:42:09 am
Hi, never heard of the logic stuff you're referring to, where would I find that? Apple sucks on the whole fcpx BS what a nightmare...
Jeremy Garchow
on Apr 22, 2014 at 3:46:20 am
It's a bug. I would file it to Apple.
Logic filters are available in the audio filters section of the effects browser.
david fuku
on Apr 22, 2014 at 3:54:41 am
Thanks, I didn't know those were logic effects..
yeah apple responds to me...and my bitching... NOT
Jeremy Garchow
on Apr 22, 2014 at 4:08:44 am
Apple does respond to some bug reports.
If they don't, perhaps it's already known.
