BMD analog audio = fcpx weirdness
Chad Smith
on Apr 3, 2014 at 1:01:23 am
Lately when using FCPX with my BMD extreme 3, (not 3D) and switch the system from digital out to analog out from the BMD card FCPX will freeze video output and start playing the audio track twice. It sounds like an echo or 1 second delay. Then I have to stop and it will be ok for a min then back to audio delays and freezing video output. Then if I change back to using the digital out of the Mac Pro Tower then things are fine. Only issue is the audio and video are 2 frames or so out of sync. OSX 10.9.2 FCPX 10.1.1
Did not used to do this. Tried installing a flashed 7970 graphics card and that is when it started. Pulled the card and still having this issue. Hmmm.
Nick Toth
Re: BMD analog audio = fcpx weirdness
on Apr 3, 2014 at 10:25:06 am
Do you have the latest BMD drivers?
anickt
Chad Smith
on Apr 3, 2014 at 1:44:44 pm
Hi Nick - No I am running 9.9.3 as I had issues with version 10 like many other users.
Nick Toth
on Apr 3, 2014 at 3:39:49 pm
Interesting. I have seen issues with previous versions that were cleared up by version 10. I have been running 10 for a while with no issues. I guess YMMV.
anickt
