Advice needed on how to add multiple movie windows into a main clip
Jeremy Park
on Mar 30, 2014 at 9:45:50 am
I am wanting to create a similar "movie in a movie" effect (sorry not sure how else to describe it) as seen with polaroids in this clip at 40 secs
I was wondering if it were best to have the polaroids painted as a green screen and lock off the shot and then add movement and other clips in post... or if there were a better / easier way to approach it.
thanks
Jeremy
John Fishback
Re: Advice needed on how to add multiple movie windows into a main clip
on Mar 30, 2014 at 9:04:44 pm
I can think of 2 ways to do this. All graphics in Motion or AfterFX, or shooting the scene with white cards for the polaroid backgrounds then tracking those shapes and inserting the videos. You could do the latter inside FCPX using CoreMelt's excellent TrackX plugin (with Mocha). I'm not sure which way is easiest. I'd probably try the tracking approach.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Jeremy Park
on Mar 31, 2014 at 8:21:34 am
thanks John... I'll look into that tracking option for FCPX. Sounds perfect. The trick will be how they overlap I guess... I did think about drop boxes in motion but was unsure how the over lap and tracking would work... thanks again
John Fishback
on Mar 31, 2014 at 2:33:14 pm
CoreMelt also has a great mask tool that also tracks called SliceX. Using that would help with the overlap. The are demos and tutorials at CoreMelt.
John
