Can I erase my FCPX 10.1.1 Library & Events and Start Over Clean?
Ned Miller
on Mar 23, 2014 at 10:40:40 pm
I have just started with X and downloaded some exercise files from the Lynda tutorial site and had some Projects & Events from when I was using the previous version. Now it's a mess and I would like to just erase them all and start over. Is that OK? Will X start clean a new Library? I am on OS 10.9.2 if that matters.
Thanks for your advice
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.com
Nikolas Bäurle
Re: Can I erase my FCPX 10.1.1 Library & Events and Start Over Clean?
on Mar 23, 2014 at 10:58:54 pm
10.1.1 will ignore your old projects and events. Once you open it will create a library with an empty event inside. You can then update your old events and projects, X will look for the old folder structure and create a library with an event containing your updated projects, and all the updated events.
Of course, if you don't want your old practice events an projects you can erase them, X won't read them anyway unless you tell it to update.
"Always look on the bright side of life" - Monty Python
Bret Williams
on Mar 24, 2014 at 12:02:41 am
And of course you don't want just "A" library. If you work like most, you want a library for each job you do. And I use the word job of course because FCPX hijacked the word project.
