Relinking clips issue
James Culbertson
on Mar 21, 2014 at 8:35:48 pm
Somehow two externally linked video files went missing in the event and when I now try to relink them I am told that they are incompatible (the original file and the new file have no shared media range.
However, the files are the exact files I used initially so I am not sure what to do. They have not been touched by any Adobe or other 3rd party apps.
Any suggestions?
Charlie Austin
Re: Relinking clips issue
on Mar 21, 2014 at 9:16:44 pm
[James Culbertson] "Any suggestions?
I'm sure others will chime in, but take a look at this:
http://telemarq.com/products/fcpxchange/
Have not tried it, but I've heard it will work...
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
James Culbertson
on Mar 21, 2014 at 9:41:44 pm
Interesting. Didn't work for me though.
The only difference I can see between the older missing version and the newly importer version of the same clip is the media start and end is different (duration is the same). I'm not sure how that would have changed.
Jeremy Garchow
on Mar 22, 2014 at 2:24:21 am
What is the original source of the clips?
James Culbertson
Re: Relinking clips issue - fixed
on Mar 22, 2014 at 5:03:22 am
Sent from various clients for another client's reel edit.
Turns out I just needed to add .mov to the file name and things reconnected correctly.
