FinalCut X Nightmare with LONG PROJETCS..
robert reed
on Mar 18, 2014 at 11:28:03 pm
Hi
Ive been wasting so much time and money of late trying to complete a long project using FCX>..
Ive upgraded my MAc 3,1 ...8 core 3.2, 24 gig of ram, 4 gig graphics card....BUT
When working on long projects ( concerts of 60min+)..... the longer the project and more cuts...the slower, and less responsive the time line gets, and
zooming in/out or moving cuts,etc...sooooooo slow...totally unusable, and frustrating....
Tried differant users, tried clean installs, tried differant OS, differant FCX versions.....still the same...
All the footage if pro rez, and it doesn't matter if I switch to Proxy...same
It starts off Great, like butter...but as the project gets longer,,,,, the timeline gets more and more unresponsive....
I cant see why
FCX cant deal with a project or FILM 60mins +....
I was about to drop £4000 on a new Imac or MacPRO...BUT just went to a store and BOTH ..
THE SAME !!!!!!!!!!!!!!!!!!!!!!!.....
Using the footage off the MAC PRO and creating a long project with lots of cuts....it just slowed down.
On a new MAC PRO...
Something is wrong.....
Final Cut PRO>?
ROB
Nicholas Zimmerman
Re: FinalCut X Nightmare with LONG PROJETCS..
on Mar 19, 2014 at 1:58:05 am
What sort of drives are you using. Most of my issues have been with slow HDDs and we fixed when I switched to a faster RAID. Also try using Proxy mode.
______________________________
FCP X Certified Pro, Level Two
Jeremy Garchow
on Mar 19, 2014 at 1:58:44 am
Try this: http://forums.creativecow.net/readpost/344/28466
Chris Northcross
on Mar 19, 2014 at 2:17:52 pm
Was the project started in an earlier version of FCP X and converted for use in 10.1 or was it created in 10.1?
"Whether you think you can or can't, you're right."
robert reed
on Mar 19, 2014 at 4:34:14 pm
Hi
It was originally created on an earlier version…. I know that may be problem…..
BUt I'm so far into the project , with loads of cuts,etc……
IS there a way to make it more compatible with 10.1 without re doing it all….
Also when I tried to recreate a fresh project with a nMP it was the same, starts off quick and lovely, but once you get over 25 mins with lots of cuts the timeline slows, over an hour anita its horrid…
Also using PROXY doesn't help….
Its trying to find where FCX access the power to navigate and move around the timeline, especially when you have say 100 cuts,etc….. disabling wav or frame view doesn't help,either…
Frustrating….Im I the only one this happens to…
i.e:
Create a time line that runs over 30 mins with say 8 cuts per minute….see if the zoom slider slows and the time line is slower…..
Ladislav Zamba
on Mar 19, 2014 at 7:24:01 pm
Same problem here http://mobi.creativecow.net/thread/344/28396#28594
robert reed
on Mar 19, 2014 at 8:24:12 pm
Hi
Yes that is the exact problem……..
And I suppose cutting into shorter segments may work, …..
BUt at the moment Im working concerts that run to 60 mins…..
Im being given the audio which matches my time line….. Im worried that cutting it to shorter songs/sections will mean a nightmare keeping everything in sync, as I have 9 cameras to sync up…
who stopped and started….
Ive managed to sync them all to the master 1 hour audio from the concert…
Also the audio is being constantly updated/mixed, so I need to replace the audio every couple of days with the new one…..
with it all as one long time line,its easy to keep sync and update the audio….
Will look into compound clip…
BUT… It doesn't say ANYWHERE in the advertising or manuel that FCX slows to crawl with long projects/timelines…… not a happy bunny….
Going to try Premiere Pro an see if thats the same….
robert reed
on Mar 19, 2014 at 9:22:15 pm
Go to Preferences - Spotlight - Privacy and then add the location of the FCP X back up folder (its in user - movies - FCP Backups or something like that.
Tried this.... it helps... a little better....
Also disabling the thumbnail view in time line helped a little...
I found that with the thumb nail view on, when you zoomed in and out, the HARDRIVE with the footage on went crazy/noisy, and the whole thing slows down....
kNock off the thumbnail view, which is not helpful, and the system is still sluggish, but the hard drive is not being hammered on every zoom in and out.....
So glimmers of hope.......
