hpx 170 p2 cam 720p 30pn
Craig Alan
on Mar 14, 2014 at 11:36:43 am
plays fine in cam but plays in slow motion in FC and out of sync with audio? 60p plays fine.
1) is this a camera settings problem or a FC settings problem.
2) Is there a way to capture the footage to resolve the problem?
I'm also going to ask at the panasonic P2 forum since it might be a camera settings issue.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Jeremy Garchow
Re: hpx 170 p2 cam 720p 30pn
on Mar 14, 2014 at 1:41:36 pm
Sounds like you shot 30p and not pn?
Did you check the "remove pulldown" box in the import window?
Craig Alan
on Mar 14, 2014 at 3:57:57 pm
Yeah you are correct. I wrote the post at home and thought I had it set for pn. 30P under recording setup on the 170.
Remove pulldown is correct or not correct? I believe I had it checked. But I've tried it both ways and still getting slow mo.
What settings would you recommend for the 170/FC import?
Jeremy Garchow
on Mar 14, 2014 at 4:26:03 pm
I'm not sure if I've worked with this footage in X before, but I'd tell you what I would do.
I would import with "remove pulldown" UNchecked and edit in either a 59.94 or 29.97 timeline.
FCPX should be able to correctly remove the pulldown in a 29.97 sequence (at least FCP7 could).
Jeremy
Craig Alan
on Mar 14, 2014 at 6:00:09 pm
Maybe that's possible but in X I import footage and FC just dealS with it. In the inspector it says its
960x720 29.97p DVCPROHD 720p60/30/24 linear PCM
In 7 I used to choose what I wanted In X it ewirther imports fine or it is "optimized" upon import.
Jeremy Garchow
on Mar 14, 2014 at 6:01:57 pm
[Craig Alan] "Maybe that's possible but in X I import footage and FC just dealS with it. I"
That's fine as long as it's not slow motion.
If it does come in conformed, then import without removing pulldown.
Jeremy
Craig Alan
on Mar 14, 2014 at 6:33:38 pm
I tried it wout pull down. I'll try again. Thanks for your help. Never had a problem with P2 media before now.
