show time of selected parts of the timeline
Tony Peck
on Mar 14, 2014 at 1:26:54 am
I need to get some accurate times of part of my timeline. I tried to use the range tool and it does not show the time for what is selected. I feel like I'm missing something obvious.
Tony
Jeremy Garchow
Re: show time of selected parts of the timeline
on Mar 14, 2014 at 1:53:04 am
Look underneath the timeline and it will show the time of selection.
Bill Davis
on Mar 14, 2014 at 2:14:25 am
The range select or marking an In or an Out is step one.
Step two is to click TWICE on the HUD. (time display in the center of the screen) - the display will show you the elapsed time of the resulting range.
(when the HUD shows the range brackets, the display shows the duration of the range.)
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Bret Williams
on Mar 14, 2014 at 2:26:24 am
Also, ctrl+D displays duration in the center display if the bottom of the sequence doesn't work. There's been a bug in the past where it quits showing selection duration down there.
Andreas Kiel
on Mar 14, 2014 at 1:15:06 pm
crtl-d is a good option - I mostly use it.
Also if a clip is selected and the Inspector is open you see the duration of the selected clip in the upper right of the Inspector window.
So there are many ways.
-Andreas
Spherico
http://www.spherico.com/filmtools
X-Files Pro, tools for working with FCPX
http://www.spherico.com/filmtools/X-Files/index.html
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
