Problem Loading & Exporting Project
Kyle Ketzer
on Mar 9, 2014 at 11:24:49 pm
Hey everyone,
So I'm using FCP X 10.0.9 on my Macbook Pro (2.4 GHz Intel Core i5, 8GB 1600 MHz DDR3) on Mavericks and ever since I tried to share my project, FCP crashed and would take over an hour to load back up. I've completely a few other projects without an issue using the same workflow, but now every time I try to export this project it crashes. I've tried replacing the project file with a backup version and I've cleared preferences. I've heard this problem could be caused by too many Compound Clips, but I consolidated my whole music video into one compound clip and thats the only one. Any ideas?
Jeremy Garchow
Re: Problem Loading & Exporting Project
on Mar 10, 2014 at 1:30:56 am
Try trashing render files.
If that doesn't work, try opening the compound and exporting just to see if it works.
Kyle Ketzer
on Mar 10, 2014 at 5:47:02 pm
I trashed the Render Files as well and that didn't fix anything. I also tried opening up the compound clip and exporting with no success.
Jeremy Garchow
on Mar 10, 2014 at 6:32:31 pm
Open the compound, select all, copy.
Make a new Library.
Make a new project in the event.
Copy the contents of the compound clip in to the new project.
Can you export?
If not, perhaps a piece of media is corrupt.
Kyle Ketzer
on Mar 10, 2014 at 7:05:31 pm
Thanks for the quick reply Jeremy. I'm going to try that out when I get a chance tonight and see what happens. I did use Digital Rebellion to see if any of my media was corrupted and no corrupted files were discovered.
Jeremy Garchow
on Mar 10, 2014 at 7:22:49 pm
Cool.
Let's hope this solves it.
Jeremy
