FCPX Idle CPU While Rendering, Export
Dan Edwards
on Mar 3, 2014 at 4:32:27 pm
Hello all,
I'm battling an issue with exporting or even just rendering my FCPX timeline. Activity Monitor shows me using a measly 30-40% of my CPU power for the export. Sending to Compressor uses ~165%, but that's still leaving about 60% of my CPU idle. A 4 minute export is taking upwards of 2 to 3 hours. Restarting, trashing preference files and dragging source media to internal disk space have all proven fruitless.
Here are my computer and project specs:
27" iMac (mid-2011)
3.4GHz
16GB RAM
AMD Radeon HD 6970M 2GB VRAM
10.9.1
4 minute, 1080p timeline, DSLR and JPG photos
Thanks in advance :)
Jeremy Garchow
Re: FCPX Idle CPU While Rendering, Export
on Mar 4, 2014 at 5:01:02 am
Any filters, effects, or templates?
Bret Williams
on Mar 5, 2014 at 2:25:53 am
Is it using the GPU?
Dan Edwards
on Mar 5, 2014 at 2:48:39 am
I'm using Magic Bullet Looks for some light grades, but I tried duplicating the project and removing all effects, and still had the same issue.
I was unable to monitor my GPU usage, but I've downloaded a utility and hope to test it.
Exporting a separate project on different machine utilizes 700-800% of my CPU usage, so I'm doubting it relies solely on the GPU for encoding (as I've read on other forums/threads).
Am I wrong if I identify the issue as FCPX not properly hyperthreading?
