No pdated events or projects after updating to 10.1.
Anette Olsen
on Feb 26, 2014 at 9:19:32 pm
Frustration: after updating to fcp 10.1.1 and after updating my Events and projects, they don't show in the Lobrary, and there are no new folders called Updated events.
I have Mavericks, I have tried trashing fcp preferences, nothing works. I can't access my events - what to do??
Jeremy Garchow
Re: No pdated events or projects after updating to 10.1.
on Feb 26, 2014 at 9:41:51 pm
Did you get an error or warning? Did you choose to save the Events and projects when asked?
Jeremy
Anette Olsen
on Feb 26, 2014 at 9:48:45 pm
no error warning - chose to update ALL events, projects
Jeremy Garchow
on Feb 26, 2014 at 9:52:17 pm
And did you choose to save the afterwords? You should have a dialogue box that asked you to save or cancel.
Anette Olsen
on Feb 26, 2014 at 9:53:28 pm
no box popped up, window just closed, and I was back to fcp's interface
Jeremy Garchow
on Feb 26, 2014 at 9:55:15 pm
OK. This seems to me that this process wasn't complete.
Choose File > Update Project and Events.
Then chose Locate, and point FCPX to where your Events and Projects are currently located.
Does that work?
Jeremy
Anette Olsen
on Feb 26, 2014 at 9:57:55 pm
I tried that, but the Events and Projects folders on my external harddisk were not higlighted and could not be chosen
Jeremy Garchow
on Feb 26, 2014 at 10:10:21 pm
That's correct. Next, just click "Update" on the bottom right.
Anette Olsen
on Feb 26, 2014 at 10:26:54 pm
In the meantime I installed Event Manager, and that made the trick, at least now I can see one of my updated projevcts/events, the one I need to work on!
Thanx - I'll try what you said also.
Bret Williams
on Feb 27, 2014 at 8:23:26 pm
Had you moved your projects and events? It can only update the ones it can see.
