Clip massively zoomed in...
Brian Thomas
on Feb 22, 2014 at 9:36:30 am
I'm just starting my first simple project after years of PPro.
I've hit something by mistake and one of my clips as it appears in the main window is massively zoomed in. On the timeline and up there on the left with all the other clips it looks fine. I think I've looked everywhere but no luck. How do I get it back to normal?
Many thanks in advance.
FCPX and PPro 6. iMac 24 + MBP 17". Near Geneva, Switzerland
Don Smith
Re: Clip massively zoomed in...
on Feb 22, 2014 at 9:43:33 am
Hhhmm… you viewing window is only 38% zoomed so there goes my first thought that your window is not sized correctly (Shift-Z with the window active to make sure). The only other thing I can think of is that in the Inspector for that clip, down near the bottom under 'Spatial Conform', you might have changed the setting. It is normally on 'Fit'. Try the settings there.
NewsVideo.com
Brian Thomas
on Feb 22, 2014 at 10:02:41 am
Shift-Z did it! MANY thanks :-)
