range with color correction
Craig Alan
on Feb 21, 2014 at 1:52:13 am
I tried setting a range within a clip on the timeline. But when I color corrected in the inspector the render bar indicated that the entire clip was being adjusted. How do I color correct a selected range?
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Bret Williams
Re: range with color correction
on Feb 21, 2014 at 3:20:30 am
You can't. You could slice it up and apply the correction to the resulting clip.
Craig Alan
on Feb 21, 2014 at 3:30:29 am
I was afraid of that. Never had to do this before but we shot a musical performed live and the stage lights kept changing and not all video friendly. We can blade it up but I'm surprised that you can't select a range and adjust audio or color what ever. Thanks.
Bret Williams
on Feb 21, 2014 at 3:52:39 am
I've never heard of an app color correcting a range. I think what you're looking for is keyframing. But sadly that hasn't been implemented. Hopefully someday.
John Fishback
on Feb 21, 2014 at 6:23:41 pm
You might be able to make an effect in Motion where you can publish selected keyframes. That might let you keyframe certain parameters across a c;ip.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Craig Alan
on Feb 22, 2014 at 12:27:47 am
Thanks. I could see where easing in and out of a correction would make it more natural looking bout can't see the downside to allowing any modification to apply to a selection. For now, we'll blade it up as needed.
