Strange Library Behavior
Doug Metz
on Feb 14, 2014 at 4:06:03 pm
Greetings,
I've got a single Library with one Event on an external drive (eSATA), with all media for the job in folders and linked. Everything was relatively normal, but now I've got an issue where all of the media and projects for the event have moved up one level and appear only when I select the Library. If I select the Event, I only see 2 of my imported clips. I tried to move them back via drag & drop, but the Event doesn't highlight.
Thoughts?
Doug Metz
Anode
Doug Metz
Re: Strange Library Behavior
on Feb 14, 2014 at 5:19:48 pm
Quick Update:
I created a new Event in the Library, moved everything into that event, and deleted the original. Seems to be fine - all projects, keywords, etc. are intact.
Weird.
Doug Metz
Anode
