How to blur or censor multiple faces or images
David Kirlew
on Feb 14, 2014 at 1:38:25 am
I have a client who requested me to blur multiple moving/shifting background images on one clip. I know can use censor and or shapes to create the keyframes for one image but I am having difficulty trying to do it with multiple image in the clip and shot. I did duplicate the clip to blur one of the images but if it is in the same shot can I blur both separate or will it use the same one blur effect? Will I need to duplicate the clip yet again to achieve the multiple blur effect?
David Kirlew
Reflection Concepts
Andy Neil
Re: How to blur or censor multiple faces or images
on Feb 14, 2014 at 2:30:41 am
Do you have Motion 5? Because you can create a blur effect that you publish to FCPX that will do the job without needing to duplicate anything.
Andy
http://www.timesavertutorials.com
David Kirlew
on Feb 14, 2014 at 3:07:43 am
I actually do have Motion 5 so I will give that a try.
David Kirlew
Reflection Concepts
Andy Neil
on Feb 14, 2014 at 3:24:46 am
If you need a leg up here's the basics of what you need.
Create a new effects project.
Clone the effect source layer.
Apply a mask to the clone layer. Publish the controls.
Apply a blur effect to the clone layer. Publish the controls.
Then in FCPX, you just continue to apply the effect to your clip for each blur you need to make.
Andy
Andy Mees
on Feb 14, 2014 at 2:59:49 am
Lots of free plugins for FCP X that will allow you to add isolated blurs to an image.
Alex Gollner offers a bunch here: http://blog.alex4d.com/2012/02/12/blurs-7-free-fcpx-effects/
If you have FxFactory then you can try my own one here: http://andymees.wordpress.com/region-tool/
These days I'm preferring to use Resolve Lite for this as it's super fast and easy to track and blur multiple subjects.
Cheers
Andy
Mark Morache
on Feb 14, 2014 at 6:11:38 am
I've had good luck with Alex Gollner's Circle Blur effect.
I apply the effect and dial in the radius, amount and center. At the first frame of the clip, I create a keyframe for the center parameter, then I go forward 10 frames in the timeline (shift-right arrow) and move the center of the blur to the new position, and keep on doing that until I get to the end of the clip. I play the clip from the beginning and see how the blur is tracking, making some adjustments by adding keyframes where I need to.
I then add another Circle Blur effect and do the same thing for the next blur I want to track.
You can add as many as you need.
I'd turn off the previous effects every time you add a new one, to keep the machine from slowing down, then turn them all back on when it's time to render.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
Dave Jenkins
on Feb 14, 2014 at 12:15:24 pm
Slice X by Core Melt has a great tracker that will do all the key framing for you.
Dajen Productions, Santa Barbara, CA
Mac Pro 3.5MHz 6-Core Late 2013
FCP X
Jasper Thayer
on Feb 16, 2014 at 10:41:48 am
Heya David,
I developed the FCPX "Bad Boys" plugin that achieves the effect.
Jasper Thayer
Apple Certified Trainer
https://FinalCutProX.net
