FCP X output via Kona LHi
Nigel Thompson
on Feb 7, 2014 at 6:02:25 pm
Recently started using FCP X 10.1 and installed new firmware for my LHi on Mavericks.
Im getting output via the LHi just fine ....(HDMI) except during playback the resolution drops to a preview resolution.
I have the AJA software set to 1080p 23.98 and im seeing the image quality drop everytime i hit play in FCPX ....
Is there a step im missing in FCP ?
I cant say if the SDI out is doing the same because i have not been able to hook it up to a monitor yet.
High End, Production & Post Production
in the Caribbean
http://www.bistt.com
Bret Williams
Re: FCP X output via Kona LHi
on Feb 7, 2014 at 8:14:31 pm
Are you working with fields? My BMD Express has a control panel setting to play 1 field or two when paused. It's called "remove field jitter when video is paused."
Jeremy Garchow
on Feb 7, 2014 at 8:50:04 pm
Make sure this is checked(image):
Jeremy
Nigel Thompson
on Feb 8, 2014 at 12:44:29 am
Thanks VERY much Jeremy ...... that did he trick
in the Caribbean
Bret Williams
on Feb 8, 2014 at 5:55:47 am
Doh, I read it backward. Glad you got it.
