What workflow do you suggest?
Larry Watts
on Feb 2, 2014 at 2:57:07 am
I've shot a simple cafe scene (dialogue) from three angles. Single camera, three separate clips. I recorded the audio on a Sound Devices 664 with three tracks: Lav 1, Lav 2, Boom mic.
So, I started by editing the shots to the main storyline which are quick cuts of various angles. I'm wondering if I should have made the SD 664 audio the main storyline and edited to that.
Any ideas as to best workflow?
THX
Larry
John Fishback
Re: What workflow do you suggest?
on Feb 6, 2014 at 10:35:41 pm
I'd marry the picture and sound for your bought takes and then use those to edit. You will have to balance the audio cut to cut, but that shouldn't be a big deal. The only time I put audio in the primary is if all I'm doing is editing picture against a prerecorded track.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
