Filter Used Clips
Emmanuel Tenenbaum
Filter Used Clips
on Feb 1, 2014 at 1:26:36 am
Hi everybody
I was wondering, since 10.1 we can see in the browser if clips are used.
However, is there a way to filter them with a smart collection in order to see all the used clips at once ?
It doesn't seem to be in the options for Smart Collections...
Thanks!!!!
Emmanuel Tenenbaum
http://emmanueltenenbaum.com
Jasper Thayer
Re: Filter Used Clips
on Feb 3, 2014 at 8:37:19 am
Heya Emmanuel,
You can't filter Used clips as a Smart Collection, but in the bottom-left corner there's a button to reveal the Timeline Index (Shift-Command-2). The Timeline Index shows a list of all the used clips in your project. When you click on any one of these clips your playhead will move to the beginning of the selected clip in the timeline. You can right-click a selected clip in the Storyline and choose to Reveal in Browser (Shift-F).
Hope that helps!
Jasper Thayer
Apple Certified Trainer
https://FinalCutProX.net
Emmanuel Tenenbaum
on Feb 3, 2014 at 10:58:51 am
Jasper thanks to you I discovered a new feature, thanks a lot for your answer! And discovered the concept of role, which is intersting.
I'm afraid though it doesn't help me to do what I wanted. I wanted to delete all proxy files from my project (I have more than 900 clips...), then select at once all the ones that are used, and then re-render the proxies for those clips only.
Do you know if there is any way to do that ?
Thanks!!
Emmanuel Tenenbaum
