Save RAM with keyboard shortcuts!
Loren Risker
on Jan 24, 2014 at 7:12:23 am
Can't believe I just realized this:
You can set the keyboard properties in the key command editor. Here's what I changed:
Customize keyboard shortcuts:
Clip Appearance: Clip Labels Only - option-command-w (ram saving mode - no thumbs or waveforms, really speeds it up)
Clip Appearance: Waveform and Filmstrips - optionss-fit-w (bring back the thumbnails and the waveforms)
Great way to boost performance quickly. Hope this helps someone!
OutOfFocus.TV - Original series, music videos, mini-docs.
Nikolas Bäurle
Re: Save RAM with keyboard shortcuts!
on Jan 24, 2014 at 9:36:32 am
I don't think this was possible with older versions, or I was looking for the wrong command...
Thanks for the info!
"Always look on the bright side of life" - Monty Python
Patrice Freymond
on Jan 24, 2014 at 11:08:06 am
This since 10.0.9 i believe, with alt-ctrl 1 to 6 to switch Timeline views.
I still wish there was a way to expand/reduce clip heights via shortcut too...
Patrice Freymond
Editor  Certified Trainer FCP7/X
Post Consultant
Always learning...
Nikolas Bäurle
on Jan 24, 2014 at 12:57:06 pm
[Patrice Freymond] "I still wish there was a way to expand/reduce clip heights via shortcut too..."
I hope they get that fixed soon.
Nick Toth
on Jan 24, 2014 at 2:06:24 pm
Control Option up and down arrow will cycle through the views. No key commands for clip height in the timeline however. I have F1 and F2 mapped to Clip Labels Only and Clip Waveforms Only. F3 is mapped to Large Filmstrip. I find those three the most handy.
anickt
Loren Risker
on Feb 3, 2014 at 8:48:46 pm
Didn't realize how much I screwed up this post:
Search clip appearance in the keyboard command editor.
Set Clip Labels Only (I used command-option-w) (ram saving)
Waveforms and Filmstrips (I used command-option-f) (back to normal
