Modified File issue
Jordan Mena
Modified File issue
on Jan 23, 2014 at 9:56:11 pm
a fellow editor called me into his bay in regards to a Modified file showing up red in his timeline. He has no idea how that clip was changed. Anyone else see this before. Any idea why the clip became modified. I'm guessing someone else has some how fudged it over or Xsan.
curious.
- J
Jordan Mena | Editor | Colorist | Producer
Los Angeles, CA
jordanmena.com
Loren Risker
Re: Modified File issue
on Jan 23, 2014 at 10:56:12 pm
I used to see it all the time, which version are you on?
OutOfFocus.TV - Original series, music videos, mini-docs.
Jordan Mena
on Jan 24, 2014 at 12:43:47 am
10.0.9 - will be making the jump in a couple weeks.
Los Angeles, CA
jordanmena.com
Bret Williams
on Jan 24, 2014 at 3:30:54 am
Did anyone use the file in AE or Premiere? Just opening the file in those apps alter them. There is a setting in there about writing xmp data in AE/Premiere that needs to be off.
FWIW it seems that 10.1 could care less if you modify a file. I've been rerendering over the same file with AE and it just magically relinks. If the new file is longer, I can drag it out longer. Wonderful. Normal.
Dave Jenkins
on Jan 24, 2014 at 4:27:32 pm
Bret
Same here, just finished a grading in DaVinci Resolve and when I go back to Resolve and regrade a shot it relinks in 10.1.1 no problem.
Dajen Productions, Santa Barbara, CA
Mac Pro 3.5MHz 6-Core Late 2013
FCP X
Jordan Mena
on Jan 24, 2014 at 6:40:26 pm
That would explain it. thanks guys!
Los Angeles, CA
jordanmena.com
