Can someone confirm or deny a bug?
Jeremy Garchow
on Jan 22, 2014 at 11:51:12 pm
EQ an audio clip under the "Audio Enhancements" > Equalization > EQ 'button'
Now close the EQ floating window. EQ holds.
Now click the same EQ button, EQ is now flat?
Anyone else?
Jeremy
Nick Toth
Re: Can someone confirm or deny a bug?
on Jan 23, 2014 at 12:14:37 am
Same here. I have reported it to Apple.
anickt
Jeremy Garchow
on Jan 23, 2014 at 7:48:48 pm
Thanks, Nick!
Chris Fenwick
on Jan 25, 2014 at 3:46:44 pm
I thought I was going crazy but yes, I've seen the same EQ problem... if you just trust the eq is there, and don't go into to double check it... it'll hold its setting... but yes, is is clearly wrong.
I suspect a 10.1.2 very soon.
Chris Fenwick
Director/Editor
SLCE Editorial
Oakland, CA
Jeremy Garchow
on Jan 25, 2014 at 6:54:28 pm
[Chris Fenwick] "I thought I was going crazy but yes, I've seen the same EQ problem... if you just trust the eq is there, and don't go into to double check it... it'll hold its setting... but yes, is is clearly wrong."
That describes it perfectly. Thanks, Chris.
