how do you delete unused clips while archiving in updated fcpx
Mahala Gaylord
on Jan 21, 2014 at 8:29:28 pm
Before the last fcpx update I could duplicate a project and choose an option to only copy used clips instead of the entire referenced event. Now that the updated version has combined events and projects into one it seems I can no longer do this. Is there a way?
Jeremy Garchow
Re: how do you delete unused clips while archiving in updated fcpx
on Jan 21, 2014 at 8:51:51 pm
Yes.
Select the Project in your Event. Choose File > Copy Project to Library > New Library.
Name a new library and chose to transfer the proxy and optimized media (or not).
This will create a new Library with a new Event, your Project, and only the used media.
You then want to Consolidate the Library to make sure all of the media is inside the Library for archiving.
Or if you have the media backed up separately, then you can skip the Consolidate step.
Clay Stanton
on Nov 6, 2014 at 6:46:56 am
Hi Jeremy
So can we assume there is no way to do this with 'handles' on the clips?
Jeremy Garchow
on Nov 6, 2014 at 2:37:47 pm
[Clay Stanton] "we assume there is no way to do this with 'handles' on the clips?"
That's correct, there's no trim function as of now.
