Sony Content Browser XML imports 1080/25i clips into FCPX as 720/60p!
Jiri Fiala
on Jan 14, 2014 at 11:09:41 pm
Hi!
I need to transfer essence marks (markers) from XDCam footage. The only way to do this is via Sony Content Browser.
But, when I do this (Import to FCPX via XML generated by SCB), all my clips that are in fact 1080/25i show up in FCPX as 720/60p! Files themselves are correct and when imported manually, they show up correctly as 1080/25i. But I NEED the XML to transfer over the markers...
Can anyone help? I'm sure it can be fixed by editing the XMLs, but I didn't find any relevant parameter. Thanks!
EDIT: Everything is at latest version: OSX 10.9.1, FCPX 10.1 and Content Browser 2.2.
Jon Dobson
Re: Sony Content Browser XML imports 1080/25i clips into FCPX as 720/60p!
on Feb 3, 2014 at 10:59:34 am
Did you find a solution to this? A friend of mine is suffering the same problem! Ridiculous apple would change the file structure!
Jiri Fiala
on Feb 3, 2014 at 11:07:38 am
No, sadly I didn't. I'm working around this by exporting to FCP7 XML and then translating that with 7toX. One more step, but doable.
Jon Dobson
on Feb 4, 2014 at 9:30:15 am
Ah yep thought that would be a way around it. Typical sony slow to update software.
