2:2 Pulldown issues
Craig RussillRoy
2:2 Pulldown issues
on Jan 14, 2014 at 1:35:09 pm
Hello Moo Cowers
I am having a brain freeze and need some help
we get a truckload of material that has come from 23.98 -> 25 from clients
every second if has a hold frame from a software conversion (nearest neighbour) and i am having a nightmare trying to reverse the process so we can use it.
Perfect world would be to go back to 23.98 (keeping the duration) and then we can run it via the teranex for a correct way.
So can anyone help me try and take out these hold frames on the 2:2 footage ? as we currently send back to clients to fix themselves.
Cheers
FCP 7
FCPX 10
3 x 4TB Thunderbolt R4
VC100
6 x 2D teranes 2D
4 x BMD Express
3 x ioXT
MicroHub
Ultrascope
SmartView
Check out the free iBook broadcast delivery 101 on itunes
Jeremy Garchow
Re: 2:2 Pulldown issues
on Jan 14, 2014 at 4:19:28 pm
[Craig RussillRoy] "every second if has a hold frame from a software conversion (nearest neighbour) and i am having a nightmare trying to reverse the process so we can use it."
I would imagine you are. Euro pulldown is a hard one to automatically remove.
[Craig RussillRoy] "So can anyone help me try and take out these hold frames on the 2:2 footage ? as we currently send back to clients to fix themselves."
I think that would be the only way to do it, and the best quality way to do it.
Other than that, I would run it through the Terranex to see if you can at least get to 50i. Sometimes adding more artifacts covers up other artifacts. ;)
Jeremy
Craig RussillRoy
on Jan 14, 2014 at 4:25:05 pm
Cheers mate, my thoughts exactly - it's been doing my head in !
FCP 7
FCPX 10
VC100
6 x 2D teranes 2D
4 x BMD Express
3 x ioXT
MicroHub
Ultrascope
SmartView
Jeremy Garchow
on Jan 14, 2014 at 4:33:56 pm
Perhaps you can use the Teranex to get back to 23.98? And then do another conversion from there?
It might take some trial and error, but it'd be worth a shot.
Jeremy
