TimeCode disappeared
Micha Blazer
on Jan 9, 2014 at 1:09:46 pm
I have a strange problem:
I have the following SD QuickTime file from the studio where our show is recorded:
MPEG IMX 625/50 (50 Mb/s), 720 x 576 (1048 x 576)
Linear PCM, 24 bit little-endian signed integer, 2 channels, 48000 Hz
When I import it in FCP X, the original timecode is gone. When I convert the file to ProRes and then import it in FCP X, the original timecode is there again. The TC is important because I want to make a multi clip.
I have tried this on 3 different computers and the same happens there. I was hoping that the 10.1 update would fix this for me, but it didn't.
It is not a big problem, but ProRessing all the material is a lot of work and I am curious what's causing this.
Thanks, Micha Blazer
Micha Blazer
http://www.blazhoffski.nl
Patrice Freymond
Re: TimeCode disappeared
on Jan 9, 2014 at 8:18:25 pm
are you getting your files off an EVS server (XT2 or same)?
Patrice Freymond
Editor  Certified Trainer FCP7/X
Post Consultant
Always learning...
Micha Blazer
on Jan 11, 2014 at 5:56:48 pm
Yes it's from an EVS.
Micha Blazer
Patrice Freymond
on Jan 11, 2014 at 6:44:20 pm
We're dealing with similar issues as it seems EVS is not writing TC in a way that suits FCPX (it worked fine with FCP7).
Transcoding helps with the TC issue but wastes time.
Having said that, since you want to create multiclips and you are using v 10, why not sync using audio? You can set tc for the start of your multiclip (options) and this way you should not be far off your script notes.
hope this helps
Patrice Freymond
Post Consultant
Always learning...
