Resoring Window Layout Issue Continuing
Mark Dannunzio
on Jan 8, 2014 at 8:41:23 pm
Hello,
I have took Apples advice to delete the layout folders within the Final Cut Pro app preferences but the application still gets held up at the "restoring Window Layout" screen. Final Cut will load the menu bar with a grey screen but that's about it. Are there any updated fixes to this? I am using Maverick as the OS. I have Final Cut version 10.1.
Thanks for your help!
Mark
Mark Dannunzio
Bret Williams
Re: Resoring Window Layout Issue Continuing
on Jan 8, 2014 at 11:51:48 pm
Have you created a new user?
Mark Dannunzio
on Jan 9, 2014 at 12:44:22 pm
Bret,
I will try that next, thanks.
Mark
Mark Dannunzio
Mark Dannunzio
on Jan 9, 2014 at 12:46:16 pm
Also, if I wanted to delete the Final Cut Pro App, and re-download it will I loose the Libraries when I first updated Final Cut to 10.1?
Or do all those libraries and bundles disappear once the app is deleted?
Thanks again,
Mark
Mark Dannunzio
