Any way to offset the automatic audio sync?
Kyra Dunn
on Jan 8, 2014 at 3:03:33 am
I have footage shot on a 5D where the audio is 2-3 frames out of sync from the video. Anyone who has used this camera has probably run into this.
On the slate the audio is two frames early. When I sync automatically it sync's to the camera's audio, making the sync'd production audio two frames off. If I put on markers that compensate for this, it still seems to default to the original audio waveform from the camera for the sync reference.
Is there a dialog box somewhere to tell FCPX to add a plus or minus "X" amount of frames in the process?
I'm not seeing a way around this.
Any help would be appreciated.
ALSO, Please note that I am not talking about drift or differing sample rates. Thanks in advance.
Kyra.
Dave Jenkins
Re: Any way to offset the automatic audio sync?
on Jan 8, 2014 at 4:49:11 pm
I haven't done sync in an event but did you try "open in timeline" by right clicking on the clip?
Dajen Productions, Santa Barbara, CA
MacPro 3.2GHz Quad Core - AJA Kona LHe+
FCS 3 OS X 10.7.4
FCP X, Logic Pro, Squeeze, Filemaker 10.8.3
