No video in 10.1
Sam Comer
No video in 10.1
on Jan 6, 2014 at 8:44:25 pm
At first, I thought it was just in the event browser ... I'd hover over a clip and the video would go away - thumbnail would just turn black. Now when I play back a project int he timeline, there is no video (I do get audio).
I've tried re-transcoding all of the clips, reimporting the original files, trashing preferences, even reinstalling the app altogether ... Nothing helps.
This is what I see in the event browser (Thumbnail and Filmstrip views)
I have also noticed this odd behavior in the counter
Render goes whacky
Possibly related? Is it re-rendering everything since the move to the Libraries and I can't see video until it's done?
Steve Connor
Re: No video in 10.1
on Jan 6, 2014 at 8:51:56 pm
What codec is the video?
Steve Connor
There's nothing we can't argue about on the FCPX COW Forum
Sam Comer
on Jan 6, 2014 at 9:16:12 pm
Name it.
That particular file is from a JVC XDCAM EX, but it's the same with any Pro Res, H.264 or what have you.
Sam Comer
on Jan 6, 2014 at 9:42:04 pm
OK ... some weirdness ...
I had one project that was imported into FCPx from Adobe Premiere CS6 via 7 to X. That project had a dozen or so .mts files from a Panasonic Ag-AC160. Those clips weren't showing up at all, despite reimporting them from the original AVCHD file structure, and despite FCP 10.1 supposedly being able to edit those files natively. AFTER I would review that project, I would go to another project, then this problem would occur. I deleted that project and all reference files from the library and everything seems to be a go. (Fingers crossed).
How odd is that?
David Battistella
on Jan 6, 2014 at 10:03:21 pm
Might not be a bad idea to post system details along with this post.
Battistella
______________________________
http://www.davidbattistella.com
Sam Comer
on Jan 6, 2014 at 10:07:02 pm
Loren Risker
on Jan 7, 2014 at 12:16:51 am
Is this an updated project/event? If so, what version were you using before? If you create a new library and import the clips does the same thing happen?
Have you tried putting the library on a different drive to rest for hard drive problems?
OutOfFocus.TV - Original series, music videos, mini-docs.
Sam Comer
on Jan 7, 2014 at 3:30:12 pm
Updated from 10.0.9. Haven't tired it on a different drive. I did just re-import the AVCHD files from the SD card into a new event and they work just fine in that. So I'm thinking it's either something Premiere did with the files or something that 7 to X did to them.
For now, I'll just have to edit these older projects on a trial version of Premiere and leave FCPX out of it.
