Nudging in and out points.
James Ewart
on Jan 6, 2014 at 11:49:05 am
Hello
Anybody know what he shortcut is to nudge in and out points a frame at a time in browser or in timeline please?
David Battistella
Re: Nudging in and out points.
on Jan 6, 2014 at 12:40:50 pm
Select the clip
Use the "." To nudge forward, use the "," to nudge backward.
David
______________________________
http://www.davidbattistella.com
Jason Brown
on Jan 6, 2014 at 1:16:01 pm
Doesn't this just move the clip? I believe the question is about nudging the range selected?
David Battistella
on Jan 6, 2014 at 2:49:41 pm
In that case I would select the clip. Hold the option key and drag out one frame ata time on either end.
David
James Ewart
on Jan 6, 2014 at 6:51:16 pm
but i want to nudge one frame at a time - dragging is less accurate.
David Battistella
on Jan 6, 2014 at 3:13:28 pm
Also found this great apple doc.
http://support.apple.com/kb/PH12550
Basically, you are either nudging (moving an entire clip) or trimming (changing the duration of a clip buy one or more frames)
I think the OP might be asking for a Nudge/trim feature. :)
David
James Ewart
on Jan 6, 2014 at 6:49:41 pm
that does not work for moving in and out points in browser here.
David Eaks
on Jan 6, 2014 at 3:15:00 pm
In the Timeline-
Use up/down arrows to jump to the desired edit point, select the edge of the clip you want to trim with left/right bracket, nudge the selected edit point with period/comma.
Is that what you're looking for?
I realized you must be referring to nudging the I/O point of a range selection, I was referring to nudging the ends of an actual clip.
James Ewart
on Jan 6, 2014 at 6:52:46 pm
don't work for me does it for you. One frame nudge in point? Or out point?
Oliver Peters
on Jan 6, 2014 at 4:16:06 pm
[James Ewart] "nudge in and out points a frame at a time in browser"
In the browser, use the left/right arrow (cursor) keys to move forward or backward 1 frame at a time. Park on the desired frame and hit I or O again for a new in/out mark.
- Oliver
Orlando, FL
http://www.oliverpeters.com
James Ewart
on Jan 6, 2014 at 6:54:06 pm
Got it thanks - shift I takes me to in point and then arrow and then hit I again. Bit boring having two steps
Oliver Peters
on Jan 6, 2014 at 7:07:52 pm
[James Ewart] "Bit boring having two steps"
That's the same way in most NLEs.
- Oliver
Orlando, FL
Bret Williams
on Jan 6, 2014 at 7:39:55 pm
I've never seen that feature in an NLE, but sounds like a good one.
James Ewart
on Jan 7, 2014 at 5:20:55 am
Perhaps I'm having a senior hallucination moment. I'm sure I could do this. Obviously mistaken. Must be mistaken. Been back and double checked. I am totally mistaken. Weird. How often do you need to nudge a marker left and right one frame? Maybe I'm getting muddled up with this.
