Final Cut Pro X Title Problem
Tyler Wosleger
on Jan 3, 2014 at 6:12:59 pm
Recently (Last month) whenever i use a title over a photo in FCP X, I have consistently noticed an issue when exporting.
The title will appear in a different spot than it was in FCP X project. It will move up or down several inches. I have tried directly uploading to youtube/vimeo. I have also tried exporting and it doesn't make a difference.
has anyone else experienced this problem? Any solutions out there?
Jeremy Garchow
Re: Final Cut Pro X Title Problem
on Jan 3, 2014 at 7:00:57 pm
What version of fcpx are you on?
Tyler Wosleger
on Jan 3, 2014 at 7:04:56 pm
10.0.9
Jeremy Garchow
on Jan 3, 2014 at 7:31:06 pm
There was a bug in 10.0.9 with a similar problem to this in that elements would change scale, and therefore change position due to their relative sizes.
http://forums.creativecow.net/readpost/344/24648
This bug was fixed in 10.1 and it may fix your problem, too.
The update to 10.1 is substantial, so I recommend reading the Apple White Papers and this:
http://www.philiphodgetts.com/2013/12/upgrade-your-events-and-project-to-fc...
If you can't or don't want to update, try putting the clip in the primary in a compound clip before adding the title.
Tyler Wosleger
on Jan 3, 2014 at 10:46:44 pm
thank you!
